Day of Defeat: Source
Publisher:
Valve
We used the popular remake of the World War II online multiplayer,
Day of Defeat: Source, which uses Valve's implementation of high-dynamic range rendering.  We did three five minute portions of real world game play on the dod_anzio map.  We connected to three different public servers each with a ping of less than 30ms and 16-20 players in the game when we were recording the frame rates.
Anti Aliasing and Anisotropic Filtering were controlled from inside the game, and thus the drivers were left set to "Application Controlled".  There are three options for the method of HDR used in this title.  You can either disable HDR completely, make use of "Bloom" which is just what it says and less resource hungry in comparison to "Full" which, again is just what it says.  It utilises a full dynamic range with the iris effect too.
We have written quite a bit about Half-Life 2: Lost Coast, Day of Defeat: Source and how Valve have implemented HDR in to the Source Engine.  You can check out the articles listed below for more information on The Lost Coast & Day of Defeat: Source.
We have already documented the problems with transparency supersampling Anti Aliasing on the GeForce 7900 GX2 Quad SLI configuration, meaning that the highest transparency Anti Aliasing setting available to us was transparency multisampling.  Despite this, there was still a decent performance difference between the two configurations.  The addition of another two GPUs meant that it was possible to run at SLI16xAA by virtue of the fact that each of the cards is running 4xAA separately.  We think that the drop in both average and minimum frame rates are related to the lower clocks on the GeForce 7900 GX2 cards.
The BFG Tech GeForce 7900 GTX OC SLI configuration performed well at this resolution, but was surpassed by the GeForce 7900 GX2's ability to run at a higher Anti Aliasing setting without the need for an expensive supersampling pattern.  The differences between SLI16xAA and SLI8xAA are small at such a high resolution and the lack of transparency supersampling means that many would prefer to utilise a lower Anti Aliasing setting in favour of supersampled alpha blended textures.
In many respects, we feel that the 7900 GTX SLI configuration provided more image quality benefits than the Quad SLI configuration, because transparency supersampled Anti Aliasing is of greater benefit than a higher Anti Aliasing setting.
At 2560x1600, the Quad SLI configuration was not fast enough to play the game smoothly with SLI8xAA applied.  In that respect, neither was the GeForce 7900 GTX SLI.  As a result of this, we found that the GeForce 7900 GX2 configuration was actually
slower than the BFG Tech GeForce 7900 GTX OC SLI.  The frame rate at 2560x1600 4xAA 16xAF was down in the mid-to-high 40's and the minimum frame rate was below 20 frames per second.
I'm sure you will agree that this isn't an ideal situation in an online multiplayer first-person shooter game.  As such, we felt that 2xTMS AA 16xAF with maximum details was the optimal setting for the GeForce 7900 GX2 Quad SLI configuration at 2560x1600.  In comparison, we were able to achieve smooth gameplay at 2xTSS AA 16xAF with maximum in-game details on the BFG Tech GeForce 7900 GTX OC SLI configuration at this resolution.
